56F84xx put data flash IFR on programming
Question asked by agostino facotti on Mar 26, 2018
Latest reply on Apr 11, 2018 by agostino facotti
I'm trying to use the flash NVM on a MC56F84452 both for data storage and EEPROM data.
Since I program some data on the data flash the problem is: when application starts it found the EEPROM not partitioned and then clears all the NVM block (which in turns clears my data ).
Eventually is there a way to prepare the data flash IFR filed with the linker command file or some other methods? The scope wuold be not to cause FlexNVM wiping at EEPROM partitioning.
Thanks for your help,
regards
agostino
