It is very hard to guess. You need to use the tools to check the running performance. e.g. Trace32 from Lauterbach or debugger/probe from GreenHills.
HI jimmychan
I don't know what is "Trace32 from Lauterbach or debugger/probe from GreenHills" mean,
what tools do you think I should use?
You can find the tools from here:
HI jimmychan
Thank you, could you just tell me which tools is using to check the running performance, I'm not good at finding these resource.
Best regards!
I didn't use this kind of tools because we don't write the application. You may contact the tool's company to get more details information.
