Hi all,
I'm using kinetis K10 and Codewarriors IDE. I wants to use NXP safety library IEC 60730B. I got the downloaded the latest version of library, which also supports Cortex CM4, but unfortunately the library is only compiled for IAR compiler.
Is there any possibility or workaround, so that I can use the library in my codewarrior project?
Any help shall be highly appreciated.
Best Regards
Taimur
Solved! Go to Solution.
Well, I really understood your feeling. However, the library itself was made based on IAR, unfortunately there is not plan to migrate this library to other IDE, for example the CodeWarrior. I am so sorry for the inconvenience this had caused.
Thanks for the reply.
So there is no way I can use this library in my code warrior project?
Taimur
Hi, Taimur
At present, no.
