Can someone help me with the Altivec instructions used for prefetching data into cache (vec_dst, vec_dstst,etc). i would like to know how the prefetch constant should be set. i want to access data from memory which some data points in between these 2 data
mandar_s
altivec, powerpc, mpc8641D
alexander_yakov
If my understanding of your question is correct, the question you asking is answered in E600 Core Reference Manual, Section 7.1.2.3.1 "Stream Engine Tags"
Here is a direct link to this document:
https://www.nxp.com/docs/en/reference-manual/E600CORERM.pdf
Alexander
TIC
mandar_s
Thank you for your answer
It helped me understand what vec_dst does, but i am still confused on how to calculate prefetch constatnt which has to be passed in vec_dst.
If you can help me with an example then that would be great.
alexander_yakov
Could you please clarify, what you mean by "prefetch constant"?
mandar_s
while using vec_dst instruction we have to pass 3 parameters to it i.e. address, prefetch constant(data block to be pre-fetched) and stream.
i am not able to calculated the second parameter that should be given to the vec_dst.
i had refer this document earlier but still i am not able to clarify my doubt on vec_dst.
https://www.nxp.com/docs/en/reference-manual/ALTIVECPIM.pdf
