we are using NXP 2N7002P Mosfet in pne of our Production Test Setup design which is getting damaged frequently.
Gate is controlled by GPIO from NXP LPC 1833 Controller. Drain Is pulled up from external DUT and Used for Resetting the DUT (Device under test)
Please Help Us on this.
This kind of standard products had already transfered to ----www.nexperia.cn last year.
Please also contact with them for detail.
Anyway from my side,please check the GATE drive signal and voltage level.
I don't see the pull up resistor value and pull up voltage of drain pin,please also check.
