USBDM for the JB16J, is it possible?
Question asked by Kevin Meyer on Oct 22, 2008
Latest reply on Mar 31, 2009 by Kevin Meyer
Dear pgo and everyone else,
I have discovered that I have the SOIC20 JB16JD instead of the SOIC28 JB16D.
Is it possible to implement pgo's USBDM on the 20 pin version?
Looking at the USBDM_JB16.h header, it looks like it might be possible, if I use only 1 LED and merge the RST_DRV pins from 2 to 1. The same goes for BDM_DRV and BDM_IN.
Can anyone tell me any reason why this will not be possible?
pgo, have you already implemented a source version that will fit on the 20 pin chip?
Is this a lost cause, and would I be better off trying to use the JM32's that I have? Or is it a catch-22, that I need a BDM programmer in order to program the USBDM into the JM32?
Thanks in advance.
