Imx6q - Playback sound captured from mic
Question asked by Şükrü Bahadır Arslan on Mar 20, 2018
Latest reply on Jun 26, 2018 by Diego Adrian Cuevas
I am trying to play audio and I want to record my sound with mic at the same time. But when I listen the recorded sound, I hear both speaker sound and mine voice. So how can ı eliminate the speaker sound from the mic sound ?
Details :
Used processor : imx6q
PulseAudio version : 8.0
Audio codec : sgtl5000
capture tab of alsamixer :
Capture tab of alsamixer
playback tab of alsamixer :
Device tree is like this :
sound {
compatible = "fsl,imx-sgtl5000",
"fsl,imx-audio-sgtl5000";
model = "audio-sgtl5000";
ssi-controller = <&PICO_AUD_I2S_CHANNEL>;
audio-codec = <&codec>;
audio-routing =
"MIC_IN", "Mic Jack",
"Mic Jack", "Mic Bias",
"Headphone Jack", "HP_OUT";
#if defined(PICO_AUD_MUX_INT) && defined(PICO_AUD_MUX_EXT)
mux-int-port = <PICO_AUD_MUX_INT>;
mux-ext-port = <PICO_AUD_MUX_EXT>;
#else
fsl,no-audmux = "true";
#endif
By the way,
PICO_AUD_MUX_INT is defined as 1 and PICO_AUD_MUX_EXT defined as 3
So How can ı fix this problem ?
