I want to flash bsp to NAND of i.MX 6ULL EVK using Mfg tool. Could some suggest correct settings and procedure to flash NAND using mfg tool.
Thanks in advance
Thanks in advance
Thanks Joan,
But I want support for
I want to flash bsp (u-boot, kenel,dtb,rootfs) to SDcard through USB-OTG using Mfg tool. I am using i.mx6ull evk board.
I have set boot mode to internal ROM. My board is detected and recognised as “HID-complaint device”. I have taken package “L4.9.11_1.0.0-ga_mfg-tools.tar” for mfg tool.
But I am not sure about what values to be set for parameters given in cfg.ini file for i.mx6ull board. I have searched in nxp community, but no luck.
Could you please help me for values to be set for :
[profiles]
chip = Linux
[platform]
board = ??
[LIST]
name = SDCard
[variable]
board = ??
pls refer to the link as belowNand Flash in IMX6ULL EVK
if you add new nand flash, don't forget to add them to the nand_ids.c
