What is the meaning of “PARTITION” in MPC5645S
hyacinth
Dear All,
In the description of Flash for MPC5645S,L0 to L3 are located in Patition 1,L4 to L7 are located in Patition 2...
When erase the Blocks,is there anything special within a patition?And What is the physical Meaning of  Patition here?
Chen
davidtosenovjan
Hi, code may be executed from one partition while another one is being programmed. That's the reason for flash partitions.
davidtosenovjan
hyacinth
So,when the code is executed from L1 and L2, it is not allowed to program L3?
davidtosenovjan
You are right.
hyacinth
Thanks for your reply, it's sloved the problem perfectly!
