MY-i.MX6-CB314 core module
cherryzheng
  •      CPU:i.MX6Q:Compatible with the
automotive, industrial, consumer level,
Accept the 6U/S mass customization
  •      Memory:DDR3 1GB, up to 2GB
  •      Storage:SPI NorFlash/4GB EMMC,
Up to 64GB EMMC
  •      Power Supply: 5V
  •      Size: 40mm x 80mm
  •      Temperature:
Consumer(-20°C..85°C ), up to 1GHz;
Automotive(-40°C..105°C), AEC-Q100, up to 1GHz;
Industrial( -40°C..85°C), up to 800MHz
Main Features:
  •      4x ARM Cortex-A9 up to 1 GHz per core at work
  •      200Mtri/s 1000Mpxl/s
  •      OpenGL ES 2.0$Halti, CL EP
  •      1MB L2 cache
  •      GPU 2D(Vector Graphics)
  •      32KB instruction and data caches
  •      Vivante GC355 300Mpxl/s, OpenVG1.1
  •      NEON SIMD media accelerator
  •      GPU 2D(Composition)
  •      GPU 3D
  •      Vivante GC320 600Mpxl/s, BLIT
  •       Vivante GC2000
  •      Video Decode 1080p 60h.264
  •      Hardware BCH(up to 20 corrections)
  •      Camera Interface
  •      Types: 1x 20-bit parallel, MIPI-CSI-2(2 lanes), three Simultaneous inputs
OS Support:
  •      Linux 3.0.35/Linux 3.14.52/Linux-4.1.15, Android4.4.2/Android5.1, QT4.8.5/QT5, Ubuntu12.04/Ubuntu16.04
MY-IMX6-CB314 parameter
hardware configuration
core board main model
CPU
memory capacity
storage capacity
boot mode
burning mode
other
MY-IMX6-CB200
i.MX 6QP
1G / 2G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
standard configuration:memory 1G,storage 4G
i.MX 6Q
1G / 2G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
i.MX 6U
1G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
i.MX 6S
512M / 1G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
standard configuration:memory 512M,storage 4G
MY-IMX6-CB314
i.MX 6QP
1G / 2G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
i.MX 6Q
1G / 2G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
i.MX 6U
1G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
MY-IMX6-CB336
i.MX 6QP
1G / 2G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
i.MX 6Q
1G / 2G
eMMC: 4G ~ 64G
SPI Flash
two bit dialing
Instruction:the series of core boards mentioned above can be offered in grades of automotive/industrial control/consumer electronic。standard configuration is consumer electronic。)
Model example
  • MY-IMX6-CB314-6Q5E-1G-4G
     CPU:MCIMX6Q5E
    memory size:1G
    eMMC size:4G
Operating system & version
MY-IMX6-EK200
MY-IMX6-EK314
MY-IMX6-EK336
MY-IMX6-EK140
Linux
Linux-3.0.35
YES
YES
Linux-3.14.52
YES
YES
YES
YES
Android
Android 4.2.2
YES
Android 4.4.2
YES
YES
QT
QT-4.8.5
YES
YES
YES
QT-5.5.0
YES
YES
YES
Ubuntu
Ubuntu 11.10
YES
YES
Ubuntu 12.04
YES
YES
Operating system support
Hardware interface
Display module
HDMI
1 way
1.4 port
LVDS
2 way
8bit model up to 165 Mpixels/s
RGB
1 way
24bit model
(rowspan=2|camera)
CSI
1 way
8bit model
Mipi
1 way
2 Lanes
Ethernet camera
RGMII
1 way
1000M
Audio
I2S/SSI/AC97
1 way
up to 1.4 Mbps
PCI Express
PCI Express
1 way
Gen 2.0
Storage
SD/MMC卡
2 way
4/8bit
SATA
1 way
SATA II, 3.0 Gbps
USB
USBOTG
1 way
480M high speed
USBHOST
1 way
480M high speed
CSPI
CSPI
2 way
high speed
UART
UART
5
up to 4.0 Mbps
CAN
CAN
2 way
1 Mbps each
PWM
PWM
1 way
configuration of 4 way is optional
I2C
I2C
3 way
supporting 400 kbps
IO expansion
multiple way
21 way
It can be configured without pin
Watchdog
Watchdog
1 way
Watchdog hardware
Bus
EIM
1 way
16 bit bus expansion
Debug
JTAG
1 way
JTAG debugging
Defaulted display selection
LVDS0
LVDS0 7寸 TFT crystal liquid display(24bit LVDS port)
resolution 1024X600@60Hz
white backlight
capacitor touch
LVDS1
LVDS1 7-inch TFT crystal liquid display(24bit LVDS port)
white backlight
capacitor touch
RGB
7-inch TFT crystal liquid display(24bit RGB port)
resolution 800X480@60Hz
white backlight
capacitor touch
HDMI
HDMI-output (24bit HDMI port)
1920X1080@60Hz compatible 16/18/24bpp
Definition of pin
Pin
Pin Name
Voltage
Pin
Pin Name
Voltage
P1
GND
0V
S1
GND
0V
P2
GND
0V
S2
GND
0V
P3
GND
0V
S3
CSI0_PIXCLK
2.5V
P4
UART1_RX
2.5V
S4
CSI0_VSYNCH
2.5V
P5
UART1_TX
2.5V
S5
CSI0_DAT12
2.5V
P6
AUD3_TXC
2.5V
S6
CSI0_DAT13
2.5V
P7
AUD3_TXD
2.5V
S7
CSI0_DAT19
2.5V
P8
GPIO_0_CLKO
3.3V
S8
CSI0_DATA_EN
2.5V
P9
AUD3_RXD
2.5V
S9
CSI0_DAT17
2.5V
P10
AUD3_TXFS
2.5V
S10
CSI0_DAT16
2.5V
P11
UART5_RXD
3.3V
S11
CSI0_DAT14
2.5V
P12
UART5_TXD
3.3V
S12
CSI0_DAT18
2.5V
P13
GND
0V
S13
CSI0_DAT15
2.5V
P14
GND
0V
S14
CSI0_HSYNCH
2.5V
P15
LVDSO_TX1_N
2.5V
S15
GND
0V
P16
LVDSO_TX1_P
2.5V
S16
GND
0V
P17
GND
0V
S17
CAN1_TX
3.3V
P18
LVDSO_TX2_N
2.5V
S18
CAN1_RX
3.3V
P19
LVDSO_TX2_P
2.5V
S19
GND
0V
P20
GND
0V
S20
I2C2_SDA
3.3V
P21
LVDSO_TX0_N
2.5V
S21
I2C2_SCL
3.3V
P22
LVDSO_TX0_P
2.5V
S22
GND
0V
P23
GND
0V
S23
I2C3_SDA
3.3V
P24
LVDSO_TX3_N
2.5V
S24
I2C3_SCL
3.3V
P25
LVDSO_TX3_P
2.5V
S25
GND
0V
P26
GND
0V
S26
UART4_RXD
3.3V
P27
LVDSO_CLK_N
2.5V
S27
UART4_TXD
3.3V
P28
LVDSO_CLK_P
2.5V
S28
GND
0V
P29
GND
0V
S29
CAN2_TX
3.3V
P30
DISP0_DAT18
3.3V
S30
CAN2_RX
3.3V
P31
DISP0_DAT22
3.3V
S31
GND
0V
P32
DISP0_DAT14
3.3V
S32
KEY_COL2
3.3V
P33
DISP0_DAT17
3.3V
S33
GND
0V
P34
DISP0_DAT9
3.3V
S34
LVDS1_TX1_P
2.5V
P35
DISP0_DAT12
3.3V
S35
LVDS1_TX1_N
2.5V
P36
DISP0_DAT5
3.3V
S36
GND
0V
P37
DISP0_DAT7
3.3V
S37
LVDS1_TX0_P
2.5V
P38
DISP0_CNTRST
3.3V
S38
LVDS1_TX0_N
2.5V
P39
DISP0_DAT0
3.3V
S39
GND
0V
P40
DISP0_HSYNCH
3.3V
S40
LVDS1_CLK_N
2.5V
P41
DISP0_DAT13
3.3V
S41
LVDS1_CLK_P
2.5V
P42
DISP0_DAT16
3.3V
S42
GND
0V
P43
DISP0_DAT21
3.3V
S43
LVDS1_TX2_N
2.5V
P44
DISP0_DAT20
3.3V
S44
LVDS1_TX2_P
2.5V
P45
DISP0_DAT23
3.3V
S45
GND
0V
P46
DISP0_DAT10
3.3V
S46
LVDS1_TX3_P
2.5V
P47
DISP0_DAT11
3.3V
S47
LVDS1_TX3_N
2.5V
P48
DISP0_DAT19
3.3V
S48
GND
0V
P49
DISP0_DAT15
3.3V
S49
EIM_DA15
3.3V
P50
DISP0_DAT8
3.3V
S50
EIM_WAIT
3.3V
P51
DISP0_DAT6
3.3V
S51
CSPI2_CS0
3.3V
P52
DISP0_DAT4
3.3V
S52
EIM_DA2
3.3V
P53
DISP0_DAT2
3.3V
S53
EIM_DA10
3.3V
P54
DISP0_DAT1
3.3V
S54
EIM_EB0
3.3V
P55
DISP0_DAT3
3.3V
S55
EIM_DA4
3.3V
P56
DISP0_DRDY
3.3V
S56
EIM_EB1
3.3V
P57
DISP0_VSYNCH
3.3V
S57
CSPI2_CS1
3.3V
P58
DISP0_CLK
3.3V
S58
CSPI2_MOSI
3.3V
P59
GND
0V
S59
CSPI2_CLK
3.3V
P60
UART2_CTS
3.3V
S60
EIM_DA12
3.3V
P61
UART2_RTS
3.3V
S61
EIM_DA7
3.3V
P62
UART2_RXD
3.3V
S62
EIM_DA8
3.3V
P63
UART2_TXD
3.3V
S63
EIM_DA3
3.3V
P64
UART3_RTS
3.3V
S64
EIM_DA6
3.3V
P65
UART3_RXD
3.3V
S65
EIM_DA1
3.3V
P66
UART3_TXD
3.3V
S66
EIM_DA11
3.3V
P67
UART3_CTS
3.3V
S67
CSPI2_MISO
3.3V
P68
GND
0V
S68
EIM_DA14
3.3V
P69
SD1_DAT3
3.3V
S69
EIM_DA13
3.3V
P70
SD1_DAT2
3.3V
S70
EIM_BCLK
3.3V
P71
SD1_CLK
3.3V
S71
EIM_DA5
3.3V
P72
SD1_DAT1
3.3V
S72
EIM_DA9
3.3V
P73
SD1_CMD
3.3V
S73
EIM_DA0
3.3V
P74
SD1_DAT0
3.3V
S74
CSPI2_RDY
3.3V
P75
GND
0V
S75
EIM_EB3
3.3V
P76
RGMII_INT
2.5V
S76
GND
0V
P77
RGMII_MDIO
2.5V
S77
USB_OTG_OC
3.3V
P78
RGMII_REF_CLK
2.5V
S78
USB_OTG_PWR_EN
3.3V
P79
RGMII_nRST
2.5V
S79
GND
0V
P80
RGMII_MDC
2.5V
S80
SD2_DATA1
3.3V
P81
RGMII_TD2
2.5V
S81
SD2_CMD
3.3V
P82
RGMII_TD1
2.5V
S82
SD2_DATA2
3.3V
P83
RGMII_RD3
2.5V
S83
SD2_DATA3
3.3V
P84
RGMII_RX_CTL
2.5V
S84
SD2_DATA0
3.3V
P85
RGMII_TX_CTL
2.5V
S85
SD2_CLK
3.3V
P86
RGMII_TXC
2.5V
S86
GPIO1_24
3.3V
P87
RGMII_RD1
2.5V
S87
GPIO1_26
3.3V
P88
RGMII_TD0
2.5V
S88
GPIO1_30
3.3V
P89
RGMII_RD0
2.5V
S89
GPIO1_27
3.3V
P90
RGMII_RXC
2.5V
S90
GPIO1_29
3.3V
P91
RGMII_RD2
2.5V
S91
MX6_ONOFF
3.3V
P92
RGMII_TD3
2.5V
S92
BOOT_MODE1
3.3V
P93
GND
0V
S93
BOOT_MODE0
3.3V
P94
SATA_RXN
2.5V
S94
GPIO2_5
3.3V
P95
SATA_RXP
2.5V
S95
GPIO2_4
3.3V
P96
GND
0V
S96
GPIO2_0
3.3V
P97
SATA_TXN
2.5V
S97
GPIO2_2
3.3V
P98
SATA_TXP
2.5V
S98
GPIO6_11
3.3V
P99
GND
0V
S99
GPIO6_9
3.3V
P100
USB_HOST_DP
5V
S100
GPIO2_6
3.3V
P101
USB_HOST_DN
5V
S101
GPIO2_3
3.3V
P102
GND
0V
S102
GPIO2_7
3.3V
P103
USB_OTG_VBUS
5V
S103
GPIO6_16
3.3V
P104
USB_H1_VBUS
5V
S104
GPIO2_1
3.3V
P105
USB_H1_OC
3.3V
S105
GPIO6_7
3.3V
P106
USB_OTG_ID
3.3V
S106
GPIO6_14
3.3V
P107
USB_H1_PWR_EN
3.3V
S107
GPIO6_8
3.3V
P108
GND
0V
S108
GPIO6_10
3.3V
P109
USB_OTG_DP
5V
S109
GPIO6_15
3.3V
P110
USB_OTG_DN
5V
S110
CSPI1_CS0
3.3V
P111
GND
0V
S111
CSPI1_MOSI
3.3V
P112
CLK1_N
2.5V
S112
CSPI1_CLK
3.3V
P113
CLK1_P
2.5V
S113
CSPI1_RDY
3.3V
P114
GND
0V
S114
CSPI1_MISO
3.3V
P115
PCIE_TXM
2.5V
S115
GND
0V
P116
PCIE_TXP
2.5V
S116
SD3_DATA2
3.3V
P117
GND
0V
S117
SD3_CLK
3.3V
P118
PCIE_RXP
2.5V
S118
SD3_DATA3
3.3V
P119
PCIE_RXM
2.5V
S119
SD3_RST
3.3V
P120
GND
0V
S120
SD3_DATA0
3.3V
P121
CSI_D1P
2.5V
S121
SD3_DATA1
3.3V
P122
CSI_D1M
2.5V
S122
SD3_CMD
3.3V
P123
GND
0V
S123
SD3_DATA6
3.3V
P124
CSI_D0M
2.5V
S124
SD3_DATA7
3.3V
P125
CSI_D0P
2.5V
S125
SD3_DATA5
3.3V
P126
GND
0V
S126
SD3_DATA4
3.3V
P127
CSI_CLK0P
2.5V
S127
GND
0V
P128
CSI_CLK0M
2.5V
S128
JTAG_TDO
3.3V
P129
GND
0V
S129
JTAG_TCK
3.3V
P130
DSI_REXT
2.5V
S130
JTAG_TDI
3.3V
P131
GND
0V
S131
JTAG_TMS
3.3V
P132
DSI_D0P
2.5V
S132
nJTAG_TRST
3.3V
P133
DSI_D0M
2.5V
S133
GND
0V
P134
GND
0V
S134
HDMI_CLKP
2.5V
P135
DSI_D1P
2.5V
S135
HDMI_CLKM
2.5V
P136
DSI_D1M
2.5V
S136
GND
0V
P137
GND
0V
S137
HDMI_D1P
2.5V
P138
DSI_CLK0M
2.5V
S138
HDMI_D1M
2.5V
P139
DSI_CLK0P
2.5V
S139
GND
0V
P140
GND
0V
S140
HDMI_D2P
2.5V
P141
I2C1_SDA
2.5V
S141
HDMI_D2M
2.5V
P142
I2C1_SCL
2.5V
S142
GND
0V
P143
GPIO1_4
3.3V
S143
HDMI_D0M
2.5V
P144
GPIO7_13
3.3V
S144
HDMI_D0P
2.5V
P145
GPIO7_12
3.3V
S145
GND
0V
P146
GPIO1_5
3.3V
S146
HDMI_HPD
2.5V
P147
GPIO7_11
3.3V
S147
HDMI_CEC_IN
2.5V
P148
nRESET
3.3V
S148
GND
0V
P149
2P5V
2.5V
S149
3P3V
3.3V
P150
2P5V
2.5V
S150
3P3V
3.3V
P151
GND
0V
S151
3P3V
3.3V
P152
GND
0V
S152
3P3V
3.3V
P153
GND
0V
S153
5VIN
5V
P154
GND
0V
S154
5VIN
5V
P155
GND
0V
S155
5VIN
5V
P156
GND
0V
S156
5VIN
5V
S157
5VIN
5V
S158
5VIN
5V
If you would like to know more about our products, please visit our website www.myzr-tech.com or email to enquiry@myzr.com.cn.
