Xtal oscillators are popular and used to the board such as MCIMX6Q-SDB and MCIMX7D-SDB.
Is it OK to replace Xtal oscillators with MEMS oscillators as following?
https://www.mouser.com/applications/mems-oscillators/
https://www.mouser.com/Passive-Components/Frequency-Control-Timing-Devices/Oscillators/Standard-Cloc...
32.768kHz
24MHz
Can anyone help me?
Solved! Go to Solution.
Hi torus1000
in general yes they can be replaced, based on frequency stability
described in i.MX6 System Development User’s Guide
https://www.nxp.com/docs/en/user-guide/IMX6DQ6SDLHDG.pdf
Probably one will have to place level shifter, please check datasheet of
specific mems chip and Development User’s Guide for necessary signal levels.
Hi torus1000
Dear Igor igorpadykov
> please check ... and Development User’s Guide for necessary signal levels.
Actually our client use MCIMX7D-SDB.
So I checked IMX7DSHDG.pdf then found follwing description.
https://community.nxp.com/message/820468?commentID=820468#comment-820468
https://www.nxp.com/docs/en/user-guide/IMX7DSHDG.pdf
For RTC_XTALI VIL and VIH voltage levels, see the
latest i.MX 7 series datasheet available at nxp.com.
But I couldn't find neither VIL nor VIH in the latest datasheet.
https://www.nxp.com/docs/en/data-sheet/IMX7DCEC.pdf
https://community.nxp.com/message/360353
Unfortunately we do not have such detail information of the XTAL spec.
(Q1) Did your answer "necessary signal levels" mean VIL and VIH?
(Q2) If yes, where can I get VIL and VIH spec for RTC_XTALI and XTALI pins?
Thanks.
Hi torus1000
yes
