LTIB repository compromised?
RobertoG
I decided to re-install LTIB in my CentOS 5 workstation to start from scratch. When I re-downloaded the "netinstall" perl script (from bitshrine.org) and ran it, it exited with an error. I opened the script and I found HTML tags for "prescription drugs" advertising. The same thing appears in the busybox-1-sortlibm.patch file in the gpp folder.
This is very odd. Can someone confirm it?
fsl_linux_spt
You are right.  The bitshrine site was compromised.
We are in process of restoring the packages and addressing the issue.
