Hi, Dear Experts:
When I am developping my custom T2080 board, the U-BOOT has startup normally.
Then, I download the kernel uImage, FileSystem and dtb, However, It can not start up, and die at:
The attachment is the startup log!
Expect your reply and thank you very much!
Solved! Go to Solution.
I have solved this question,thx!~
I have the same question, How did you solved it?
Thanks!
The startup config's fault! I excute the command " setenv bootargs ‘root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 console=ttyS0,115200’
Then, It is Okay!
