Hi Dear dumitru-daniel.popa
I have attached the files which I built using my compiler. Please have a look.
Many thanks in advance,
Mahd
Mahd
Hi dumitru-daniel.popa,
Thank you so much for your help.
I have installed hotfix_6 and everything is working totally fine now
Mahd Khalid
Hi Mahd,
Sorry for delay. I've checked the code you have sent me.
The main difference between you generated code and mine is in the flexcan_init_fnc() function:
Please install HotFix_6 patch in order to fix it: https://community.nxp.com/thread/451804#comment-954427
This is a cumulative patch that fix the issue.
Please confirm you have it working. FYI, these are the HW settings i've tested with:
- 12V external power supply
- 120ohm termination resistor
Hope this helps!
