PN7150 problem to restart discovery after stop
phlb
Hello
I use NXP PN7150. It works correctly but in this specific situation not.
I try restart my discovery loop with NxpNci_StartDiscovery() some seconds after I called NxpNci_StopDiscovery().
NxpNci_StartDiscovery() return an error.
Do you have a suggestion or have you ever had this problem?
Thanks for your help.
phlb.
phlb
problem fixed. it was an issue with dma and cortex M7 data cache, i2c and SDIO use DMA cacheable memory zone. problem of concurrent access.
