I would like to measure the RAM/ROM size of the code i have compiled using s32d, MPC5744P, gcc. Where to look for the information in the map file. It is possible to get this information for every file.
Thankyou
enable print size for your project by right click on project name -> properties -> C/C++ build -> settings
Perfect article related to GNU size utility is here: text, data and bss: Code and Data Size Explained | MCU on Eclipse
Hope it helps.
Jiri
Hope it helps.
Jiri
