i.mx6 rotate 90 degree
Question asked by Alex Berenshtein on Mar 12, 2018
Latest reply on Mar 12, 2018 by igorpadykov
I use kernel 4.1.15
I apply the following changes.
In file:  drivers/video/mxc/mxc_ipuv3_fb.c
        //if (var->rotate > IPU_ROTATE_VERT_FLIP)
                var->rotate = IPU_ROTATE_180;
                //var->rotate = IPU_ROTATE_NONE;
Hard-code  the value  "var->rotate" it work.
I try rotate display on 90 / 270 degree , for example :
    var->rotate =  IPU_ROTATE_90_RIGHT;
    var->rotate = IPU_ROTATE_90_RIGHT_VFLIP;
     var->rotate = IPU_ROTATE_90_RIGHT_HFLIP;
      var->rotate = IPU_ROTATE_90_LEFT;
- but no working.
I would like rotate display on 90 / 270 degree use hard-code (in kernel only ).
Best regards.
