GPIO state in S32K14X low power VLPS mode
sreenivasuluvak
I have question related to S23K14X low power mode VLPS . NXP application note AN5425( Power Management for S32K14x ), table 4 mentions that GPIO/PORT module is off in VLPS mode. What does “off” mean ?  Does it mean that the Micro can’t ( or keep the pin at a desired  level ) drive  a port pin  in VLPS mode?  If yes, what is the state of GPIO pins in VLPS mode? We are basically trying to confirm whether we can assert( either high or low) certain GPIO pins in VLPS mode in order to reduce quiescent current.
danielmartynek
The GPIO/PORTs are off but their states are maintained in VLPS.
To reduce the current, you can set them as inputs and enable their internal pull resistors.
