HVPMC3PH PCB Files in ASCII Format
appioninc
  Can someone please provide the PCB files for the HVPMC Eval Kit in ASCII format?  They are in Cadence/Allegro format which is not compatible with other PCB tools.  If you can save the PCB file in an ASCII format this is typically importable into other PCB tools.
Minimally can you provide a PDF that shows all the traces on each layer of the PCB?
I am particularly interested to understand some of the PCB trace widths and spacing.
Frank
miduo
Sorry, I'm afraid we only have the layout-footprint files on Cadence/Allegro format as you metioned. We do not provide one with ASCII format. Sorry for the inconvenience this may caused.
