If you would like to know more about our products, please visit www.myzr.com.cn or email to enquiry@myzr.com.cn.
automotive, industrial, consumer level,
Accept the 6U/S mass customization
Up to 64GB EMMC
Consumer(-20°C..85°C), up to 1GHz;
Automotive(-40°C..105°C), AEC-Q100, up to 1GHz;
Industrial(-40°C..85°C), up to 800MHz
Main Features:
4x ARM Cortex-A9 up to 1 GHz per core at work
200Mtri/s 1000Mpxl/s OpenGL ES 2.0&Halti, CL EP
1MB L2 cache
GPU 2D(Vector Graphics)
32KB instruction and data caches
Vivante GC355 300Mpxl/s, Open VG1.1
NEON SIMD media accelerator
GPU 2D(Composition)
GUP 3D
Vivante GC320 600Mpxl/s, BLIT
Vivante GC2000
Video Decode 1080p 60h.264
Hardware BCH(up to 20 corrections)
Video Encode: 1080p30H.264 BP 2x 720 encode
Camera Interface
Types: 1x 20-bit parallel, MIPI-CSI-2(4 lanes), three simultaneous inputs
OS Support:
Display module | HDMI | 1 way | 1.4 port |
LVDS | 2 way | 8bit model up to 165 Mpixels/s | |
RGB | 1 way | 24bit model | |
(rowspan=2|camera) | CSI | 1 way | 8bit model |
Mipi | 1 way | 2 Lanes | |
Ethernet camera | RGMII | 1 way | 1000M |
Audio | I2S/SSI/AC97 | 1 way | up to 1.4 Mbps |
PCI Express | PCI Express | 1 way | Gen 2.0 |
Storage | SD/MMC卡 | 2 way | 4/8bit |
SATA | 1 way | SATA II, 3.0 Gbps | |
USB | USBOTG | 1 way | 480M high speed |
USBHOST | 1 way | 480M high speed | |
CSPI | CSPI | 2 way | high speed |
UART | UART | 5 | up to 4.0 Mbps |
CAN | CAN | 2 way | 1 Mbps each |
PWM | PWM | 1 way | configuration of 4 way is optiona |
I2C | I2C | 3 way | supporting 400 kbps |
IO expansion | multiple way | 21 way | It can be configured without pin |
Watchdog | Watchdog | 1 way | Watchdog hardware |
Bus | EIM | 1 way | 16 bit bus expansion |
Debug | JTAG | 1 way | JTAG debugging |
Defaulted display selection
7-inch TFT crystal liquid display(24bit RGB port)
resolution 800X480@60Hz
white backlight
capacitor touch
Definition of pin
No. | Join Point | The corresponding CPU pin | Signal name of pin
| The default function of the pin | The interface of the pin | |
1 | G23 | 5VIN | 5VIN | 5VIN | 5VIN | |
2 | G24 | 5VIN | 5VIN | 5VIN | 5VIN | |
3 | H23 | 5VIN | 5VIN | 5VIN | 5VIN | |
4 | J23 | 5VIN | 5VIN | 5VIN | 5VIN | |
5 | J24 | 5VIN | 5VIN | 5VIN | 5VIN | |
6 | H24 | 5VIN | 5VIN | 5VIN | 5VIN | |
7 | V1 | CSI0_DAT4 | AUD3_TXC | AUD3_TXC | AUDMUX | |
8 | V2 | CSI0_DAT5 | AUD3_TXD | AUD3_TXD | AUDMUX | |
9 | V3 | CSI0_DAT7 | AUD3_RXD | AUD3_RXD | AUDMUX | |
10 | W1 | CSI0_DAT6 | AUD3_TXFS | AUD3_TXFS | AUDMUX | |
11 | W2 | GPIO_0 | GPIO_0_CLKO | CCM_CLKO1 | CCM | |
12 | AA26 | EIM_D17 | CSPI1_MISO | ECSPI1_MISO | ECSPI1 | |
13 | AB26 | EIM_D16 | CSPI1_CLK | ECSPI1_SCLK | ECSPI1 | |
14 | AB27 | EIM_D18 | CSPI1_MOSI | ECSPI1_MOSI | ECSPI1 | |
15 | W26 | EIM_CS0 | CSPI2_CLK | ECSPI2_SCLK | ECSPI2 | |
16 | W27 | EIM_CS1 | CSPI2_MOSI | ECSPI2_MOSI | ECSPI2 | |
17 | Y25 | EIM_OE | CSPI2_MISO | ECSPI2_MISO | ECSPI2 | |
18 | A25 | RGMII_TD0 | RGMII_TD0 | RGMII_TD0 | ENET | |
19 | A26 | RGMII_RX_CTL | RGMII_RX_CTL | RGMII_RX_CTL | ENET | |
20 | A27 | RGMII_TX_CTL | RGMII_TX_CTL | RGMII_TX_CTL | ENET | |
21 | B25 | RGMII_RD3 | RGMII_RD3 | RGMII_RD3 | ENET | |
22 | B26 | RGMII_RD0 | RGMII_RD0 | RGMII_RD0 | ENET | |
23 | B27 | RGMII_TD2 | RGMII_TD2 | RGMII_TD2 | ENET | |
24 | C25 | RGMII_RXC | RGMII_RXC | RGMII_RXC | ENET | |
25 | C26 | RGMII_RD2 | RGMII_RD2 | RGMII_RD2 | ENET | |
26 | C27 | RGMII_TD3 | RGMII_TD3 | RGMII_TD3 | ENET | |
27 | D25 | RGMII_TD1 | RGMII_TD1 | RGMII_TD1 | ENET | |
28 | D26 | RGMII_TXC | RGMII_TXC | RGMII_TXC | ENET | |
29 | D27 | RGMII_RD1 | RGMII_RD1 | RGMII_RD1 | ENET | |
30 | E25 | ENET_MDC | RGMII_MDC | ENET_MDC | ENET | |
31 | F26 | ENET_MDIO | RGMII_MDIO | ENET_MDIO | ENET | |
32 | F27 | ENET_REF_CLK | RGMII_REF_CLK | ENET_TX_CLK | ENET | |
33 | Y1 | GPIO_7 | CAN1_TX | CAN1_TX | FLEXCAN1 | |
34 | Y2 | GPIO_8 | CAN1_RX | CAN1_RX | FLEXCAN1 | |
35 | AA1 | KEY_ROW4 | CAN2_RX | CAN2_RX | FLEXCAN2 | |
36 | AA2 | KEY_COL4 | CAN2_TX | CAN2_TX | FLEXCAN2 | |
37 | AA24 | GND | GND | GND | GND | |
38 | AA3 | GND | GND | GND | GND | |
39 | AB24 | GND | GND | GND | GND | |
40 | AB3 | GND | GND | GND | GND | |
41 | AC3 | GND | GND | GND | GND | |
42 | AD10 | GND | GND | GND | GND | |
43 | AD11 | GND | GND | GND | GND | |
44 | AD12 | GND | GND | GND | GND | |
45 | AD13 | GND | GND | GND | GND | |
46 | AD14 | GND | GND | GND | GND | |
47 | AD15 | GND | GND | GND | GND | |
48 | AD16 | GND | GND | GND | GND | |
49 | AD17 | GND | GND | GND | GND | |
50 | AD18 | GND | GND | GND | GND | |
51 | AD19 | GND | GND | GND | GND | |
52 | AD20 | GND | GND | GND | GND | |
53 | AD21 | GND | GND | GND | GND | |
54 | AD3 | GND | GND | GND | GND | |
55 | AD4 | GND | GND | GND | GND | |
56 | AD5 | GND | GND | GND | GND | |
57 | AD6 | GND | GND | GND | GND | |
58 | AD7 | GND | GND | GND | GND | |
59 | AD8 | GND | GND | GND | GND | |
60 | AD9 | GND | GND | GND | GND | |
61 | D10 | GND | GND | GND | GND | |
62 | D11 | GND | GND | GND | GND | |
63 | D12 | GND | GND | GND | GND | |
64 | D13 | GND | GND | GND | GND | |
65 | D14 | GND | GND | GND | GND | |
66 | D16 | GND | GND | GND | GND | |
67 | D17 | GND | GND | GND | GND | |
68 | D18 | GND | GND | GND | GND | |
69 | D19 | GND | GND | GND | GND | |
70 | D20 | GND | GND | GND | GND | |
71 | D21 | GND | GND | GND | GND | |
72 | D22 | GND | GND | GND | GND | |
73 | D23 | GND | GND | GND | GND | |
74 | D24 | GND | GND | GND | GND | |
75 | D4 | GND | GND | GND | GND | |
76 | D5 | GND | GND | GND | GND | |
77 | D7 | GND | GND | GND | GND | |
78 | D8 | GND | GND | GND | GND | |
79 | D9 | GND | GND | GND | GND | |
80 | E17 | GND | GND | GND | GND | |
81 | E18 | GND | GND | GND | GND | |
82 | E19 | GND | GND | GND | GND | |
83 | E20 | GND | GND | GND | GND | |
84 | E21 | GND | GND | GND | GND | |
85 | E22 | GND | GND | GND | GND | |
86 | E23 | GND | GND | GND | GND | |
87 | F23 | GND | GND | GND | GND | |
88 | H3 | GND | GND | GND | GND | |
89 | J3 | GND | GND | GND | GND | |
90 | K23 | GND | GND | GND | GND | |
91 | K24 | GND | GND | GND | GND | |
92 | L23 | GND | GND | GND | GND | |
93 | L24 | GND | GND | GND | GND | |
94 | P24 | GND | GND | GND | GND | |
95 | R24 | GND | GND | GND | GND | |
96 | T24 | GND | GND | GND | GND | |
97 | W3 | GND | GND | GND | GND | |
98 | Y3 | GND | GND | GND | GND | |
99 | A22 | SD1_DAT0 | SD1_DAT0 | GPIO1_IO16 | GPIO1 | |
100 | A23 | SD2_CLK | SD2_CLK | GPIO1_IO10 | GPIO1 | |
101 | A24 | SD2_DAT0 | SD2_DAT0 | GPIO1_IO15 | GPIO1 | |
102 | AB25 | ENET_RX_ER | GPIO1_24 | GPIO1_IO24 | GPIO1 | |
103 | AC25 | ENET_TXD1 | GPIO1_29 | GPIO1_IO29 | GPIO1 | |
104 | AC26 | ENET_RXD0 | GPIO1_27 | GPIO1_IO27 | GPIO1 | |
105 | AC27 | ENET_RXD1 | GPIO1_26 | GPIO1_IO26 | GPIO1 | |
106 | AD22 | GPIO_5 | GPIO1_5 | GPIO1_IO05 | GPIO1 | |
107 | AD23 | GPIO_2 | GPIO1_2 | GPIO1_IO02 | GPIO1 | |
108 | AD24 | GPIO_4 | GPIO1_4 | GPIO1_IO04 | GPIO1 | |
109 | AD27 | ENET_TXD0 | GPIO1_30 | GPIO1_IO30 | GPIO1 | |
110 | B21 | SD1_DAT2 | SD1_DAT2 | GPIO1_IO19 | GPIO1 | |
111 | B22 | SD1_CLK | SD1_CLK | GPIO1_IO20 | GPIO1 | |
112 | B23 | SD2_DAT1 | SD2_DAT1 | GPIO1_IO14 | GPIO1 | |
113 | B24 | SD2_DAT3 | SD2_DAT3 | GPIO1_IO12 | GPIO1 | |
114 | C21 | SD1_CMD | SD1_CMD | GPIO1_IO18 | GPIO1 | |
115 | C22 | SD1_DAT1 | SD1_DAT1 | GPIO1_IO17 | GPIO1 | |
116 | C23 | SD2_CMD | SD2_CMD | GPIO1_IO11 | GPIO1 | |
117 | C24 | SD2_DAT2 | SD2_DAT2 | GPIO1_IO13 | GPIO1 | |
118 | E26 | ENET_TX_EN | RGMII_INT | GPIO1_IO28 | GPIO1 | |
119 | E27 | ENET_CRS_DV | RGMII_nRST | GPIO1_IO25 | GPIO1 | |
120 | A18 | NANDF_D4 | GPIO2_4 | GPIO2_IO04 | GPIO2 | |
121 | A19 | NANDF_D0 | GPIO2_0 | GPIO2_IO00 | GPIO2 | |
122 | A20 | NANDF_D6 | GPIO2_6 | GPIO2_IO06 | GPIO2 | |
123 | AA25 | EIM_RW | CSPI2_CS0 | GPIO2_IO26 | GPIO2 | |
124 | B18 | NANDF_D3 | GPIO2_3 | GPIO2_IO03 | GPIO2 | |
125 | B20 | NANDF_D2 | GPIO2_2 | GPIO2_IO02 | GPIO2 | |
126 | C18 | NANDF_D7 | GPIO2_7 | GPIO2_IO07 | GPIO2 | |
127 | C19 | NANDF_D5 | GPIO2_5 | GPIO2_IO05 | GPIO2 | |
128 | C20 | NANDF_D1 | GPIO2_1 | GPIO2_IO01 | GPIO2 | |
129 | F24 | EIM_EB3 | EIM_EB3 | GPIO2_IO31 | GPIO2 | |
130 | J26 | EIM_A20 | EIM_A20 | GPIO2_IO18 | GPIO2 | |
131 | K25 | EIM_A17 | EIM_A17 | GPIO2_IO21 | GPIO2 | |
132 | K26 | EIM_A21 | EIM_A21 | GPIO2_IO17 | GPIO2 | |
133 | K27 | EIM_A22 | EIM_A22 | GPIO2_IO16 | GPIO2 | |
134 | L26 | EIM_A16 | EIM_A16 | GPIO2_IO22 | GPIO2 | |
135 | L27 | EIM_A19 | EIM_A19 | GPIO2_IO19 | GPIO2 | |
136 | M27 | EIM_A18 | EIM_A18 | GPIO2_IO20 | GPIO2 | |
137 | N26 | EIM_EB0 | EIM_EB0 | GPIO2_IO28 | GPIO2 | |
138 | U27 | EIM_EB1 | EIM_EB1 | GPIO2_IO29 | GPIO2 | |
139 | Y26 | EIM_LBA | CSPI2_CS1 | GPIO2_IO27 | GPIO2 | |
140 | AA27 | EIM_D19 | CSPI1_CS1 | GPIO3_IO19 | GPIO3 | |
141 | AC24 | EIM_D20 | EIM_D20 | GPIO3_IO20 | GPIO3 | |
142 | AD26 | EIM_D30 | USB_H1_OC | GPIO3_IO30 | GPIO3 | |
143 | AE27 | EIM_D21 | USB_OTG_OC | GPIO3_IO21 | GPIO3 | |
144 | E24 | EIM_D22 | USB_OTG_PWR_EN | GPIO3_IO22 | GPIO3 | |
145 | M25 | EIM_DA1 | EIM_DA1 | GPIO3_IO01 | GPIO3 | |
146 | M26 | EIM_DA3 | EIM_DA3 | GPIO3_IO03 | GPIO3 | |
147 | N25 | EIM_DA2 | EIM_DA2 | GPIO3_IO02 | GPIO3 | |
148 | N27 | EIM_DA6 | EIM_DA6 | GPIO3_IO06 | GPIO3 | |
149 | P25 | EIM_DA8 | EIM_DA8 | GPIO3_IO08 | GPIO3 | |
150 | P27 | EIM_DA7 | EIM_DA7 | GPIO3_IO07 | GPIO3 | |
151 | R25 | EIM_DA15 | EIM_DA15 | GPIO3_IO15 | GPIO3 | |
152 | R26 | EIM_DA13 | EIM_DA13 | GPIO3_IO13 | GPIO3 | |
153 | R27 | EIM_DA12 | EIM_DA12 | GPIO3_IO12 | GPIO3 | |
154 | T25 | EIM_DA9 | EIM_DA9 | GPIO3_IO09 | GPIO3 | |
155 | T26 | EIM_DA5 | EIM_DA5 | GPIO3_IO05 | GPIO3 | |
156 | T27 | EIM_DA0 | EIM_DA0 | GPIO3_IO00 | GPIO3 | |
157 | U25 | EIM_DA10 | EIM_DA10 | GPIO3_IO10 | GPIO3 | |
158 | U26 | EIM_DA4 | EIM_DA4 | GPIO3_IO04 | GPIO3 | |
159 | V26 | EIM_DA14 | EIM_DA14 | GPIO3_IO14 | GPIO3 | |
160 | V27 | EIM_DA11 | EIM_DA11 | GPIO3_IO11 | GPIO3 | |
161 | AD25 | KEY_COL2 | GPIO4_10 | GPIO4_IO10 | GPIO4 | |
162 | AF26 | DI0_PIN4 | DISP0_CNTRST | GPIO4_IO20 | GPIO4 | |
163 | Y27 | GPIO_19 | CSPI1_RDY | GPIO4_IO05 | GPIO4 | |
164 | J27 | EIM_A24 | EIM_A24 | GPIO5_IO04 | GPIO5 | |
165 | P26 | EIM_WAIT | EIM_WAIT | GPIO5_IO00 | GPIO5 | |
166 | U2 | CSI0_DATA_EN | CSI0_DATA_EN | GPIO5_IO20 | GPIO5 | |
167 | W25 | EIM_A25 | CSPI2_RDY | GPIO5_IO02 | GPIO5 | |
168 | A11 | SD3_DAT7 | SD3_DAT7 | GPIO6_IO17 | GPIO6 | |
169 | A13 | SD3_DAT6 | SD3_DAT6 | GPIO6_IO18 | GPIO6 | |
170 | A16 | NANDF_RB0 | GPIO6_10 | GPIO6_IO10 | GPIO6 | |
171 | A17 | NANDF_ALE | GPIO6_8 | GPIO6_IO08 | GPIO6 | |
172 | B16 | NANDF_WP_B | GPIO6_9 | GPIO6_IO09 | GPIO6 | |
173 | B17 | NANDF_CS2 | GPIO6_15 | GPIO6_IO15 | GPIO6 | |
174 | B19 | NANDF_CS3 | GPIO6_16 | GPIO6_IO16 | GPIO6 | |
175 | C15 | NANDF_CS0 | GPIO6_11 | GPIO6_IO11 | GPIO6 | |
176 | C16 | NANDF_CS1 | GPIO6_14 | GPIO6_IO14 | GPIO6 | |
177 | C17 | NANDF_CLE | GPIO6_7 | GPIO6_IO07 | GPIO6 | |
178 | L25 | EIM_A23 | EIM_A23 | GPIO6_IO06 | GPIO6 | |
179 | V25 | EIM_BCLK | EIM_BCLK | GPIO6_IO31 | GPIO6 | |
180 | B13 | SD3_RST | SD3_RST | GPIO7_IO08 | GPIO7 | |
181 | C11 | SD3_DAT5 | SD3_DAT5 | GPIO7_IO00 | GPIO7 | |
182 | C12 | SD3_DAT4 | SD3_DAT4 | GPIO7_IO01 | GPIO7 | |
183 | K1 | HDMI_D1P | HDMI_D1P | HDMI_TX_DATA1_P | HDMI | |
184 | K2 | HDMI_D1M | HDMI_D1M | HDMI_TX_DATA1_N | HDMI | |
185 | K3 | KEY_ROW2 | HDMI_CEC_IN | HDMI_TX_CEC_LINE | HDMI | |
186 | L1 | HDMI_D2M | HDMI_D2M | HDMI_TX_DATA2_N | HDMI | |
187 | L2 | HDMI_D2P | HDMI_D2P | HDMI_TX_DATA2_P | HDMI | |
188 | L3 | HDMI_HPD | HDMI_HPD | HDMI_TX_HPD | HDMI | |
189 | M1 | HDMI_CLKM | HDMI_CLKM | HDMI_TX_CLK_N | HDMI | |
190 | M2 | HDMI_CLKP | HDMI_CLKP | HDMI_TX_CLK_P | HDMI | |
191 | N1 | HDMI_D0M | HDMI_D0M | HDMI_TX_DATA0_N | HDMI | |
192 | N2 | HDMI_D0P | HDMI_D0P | HDMI_TX_DATA0_P | HDMI | |
193 | AE12 | CSI0_DAT8 | I2C1_SDA | I2C1_SDA | I2C1 | |
194 | AF12 | CSI0_DAT9 | I2C1_SCL | I2C1_SCL | I2C1 | |
195 | AE10 | KEY_COL3 | I2C2_SCL | I2C2_SCL | I2C2 | |
196 | AE11 | KEY_ROW3 | I2C2_SDA | I2C2_SDA | I2C2 | |
197 | AF10 | GPIO_3 | I2C3_SCL | I2C3_SCL | I2C3 | |
198 | AF11 | GPIO_6 | I2C3_SDA | I2C3_SDA | I2C3 | |
199 | AE13 | DISP0_DAT21 | DISP0_DAT21 | IPU1_DISP0_DATA21 | IPU1 | |
200 | AE14 | DISP0_DAT4 | DISP0_DAT4 | IPU1_DISP0_DATA04 | IPU1 | |
201 | AE15 | DI0_DISP_CLK | DISP0_CLK | IPU1_DI0_DISP_CLK | IPU1 | |
202 | AE16 | DISP0_DAT16 | DISP0_DAT16 | IPU1_DISP0_DATA16 | IPU1 | |
203 | AE17 | DISP0_DAT8 | DISP0_DAT8 | IPU1_DISP0_DATA08 | IPU1 | |
204 | AE18 | DISP0_DAT15 | DISP0_DAT15 | IPU1_DISP0_DATA15 | IPU1 | |
205 | AE19 | DISP0_DAT11 | DISP0_DAT11 | IPU1_DISP0_DATA11 | IPU1 | |
206 | AE20 | DISP0_DAT18 | DISP0_DAT18 | IPU1_DISP0_DATA18 | IPU1 | |
207 | AE21 | DISP0_DAT19 | DISP0_DAT19 | IPU1_DISP0_DATA19 | IPU1 | |
208 | AE22 | DISP0_DAT17 | DISP0_DAT17 | IPU1_DISP0_DATA17 | IPU1 | |
209 | AE23 | DISP0_DAT9 | DISP0_DAT9 | IPU1_DISP0_DATA09 | IPU1 | |
210 | AE24 | DISP0_DAT5 | DISP0_DAT5 | IPU1_DISP0_DATA05 | IPU1 | |
211 | AE25 | DISP0_DAT2 | DISP0_DAT2 | IPU1_DISP0_DATA02 | IPU1 | |
212 | AE26 | DI0_PIN2 | DISP0_HSYNCH | IPU1_DI0_PIN02 | IPU1 | |
213 | AF13 | DISP0_DAT10 | DISP0_DAT10 | IPU1_DISP0_DATA10 | IPU1 | |
214 | AF14 | DISP0_DAT13 | DISP0_DAT13 | IPU1_DISP0_DATA13 | IPU1 | |
215 | AF15 | DISP0_DAT3 | DISP0_DAT3 | IPU1_DISP0_DATA03 | IPU1 | |
216 | AF16 | DI0_PIN3 | DISP0_VSYNCH | IPU1_DI0_PIN03 | IPU1 | |
217 | AF17 | DISP0_DAT20 | DISP0_DAT20 | IPU1_DISP0_DATA20 | IPU1 | |
218 | AF18 | DISP0_DAT1 | DISP0_DAT1 | IPU1_DISP0_DATA01 | IPU1 | |
219 | AF19 | DI0_PIN15 | DISP0_DRDY | IPU1_DI0_PIN15 | IPU1 | |
220 | AF20 | DISP0_DAT23 | DISP0_DAT23 | IPU1_DISP0_DATA23 | IPU1 | |
221 | AF21 | DISP0_DAT22 | DISP0_DAT22 | IPU1_DISP0_DATA22 | IPU1 | |
222 | AF22 | DISP0_DAT14 | DISP0_DAT14 | IPU1_DISP0_DATA14 | IPU1 | |
223 | AF23 | DISP0_DAT12 | DISP0_DAT12 | IPU1_DISP0_DATA12 | IPU1 | |
224 | AF24 | DISP0_DAT7 | DISP0_DAT7 | IPU1_DISP0_DATA07 | IPU1 | |
225 | AF25 | DISP0_DAT6 | DISP0_DAT6 | IPU1_DISP0_DATA06 | IPU1 | |
226 | AF27 | DISP0_DAT0 | DISP0_DAT0 | IPU1_DISP0_DATA00 | IPU1 | |
227 | P1 | CSI0_DAT14 | CSI0_DAT14 | IPU1_CSI0_DATA14 | IPU1 | |
228 | P2 | CSI0_DAT19 | CSI0_DAT19 | IPU1_CSI0_DATA19 | IPU1 | |
229 | P3 | CSI0_DAT16 | CSI0_DAT16 | IPU1_CSI0_DATA16 | IPU1 | |
230 | R1 | CSI0_DAT17 | CSI0_DAT17 | IPU1_CSI0_DATA17 | IPU1 | |
231 | R2 | CSI0_DAT13 | CSI0_DAT13 | IPU1_CSI0_DATA13 | IPU1 | |
232 | R3 | CSI0_DAT12 | CSI0_DAT12 | IPU1_CSI0_DATA12 | IPU1 | |
233 | T1 | CSI0_DAT15 | CSI0_DAT15 | IPU1_CSI0_DATA15 | IPU1 | |
234 | T2 | CSI0_DAT18 | CSI0_DAT18 | IPU1_CSI0_DATA18 | IPU1 | |
235 | T3 | CSI0_PIXCLK | CSI0_PIX CLK | IPU1_CSI0_PIXCLK | IPU1 | |
236 | U1 | CSI0_VSYNC | CSI0_VSYNCH | IPU1_CSI0_VSYNC | IPU1 | |
237 | U3 | CSI0_MCLK | CSI0_HSYNCH | IPU1_CSI0_HSYNC | IPU1 | |
238 | AB1 | LVDS0_TX0_N | LVDS0_TX0_N | LVDS0_DATA0_N | LDB | |
239 | AB2 | LVDS0_TX0_P | LVDS0_TX0_P | LVDS0_DATA0_P | LDB | |
240 | AC1 | LVDS0_CLK_P | LVDS0_CLK_P | LVDS0_CLK_P | LDB | |
241 | AC2 | LVDS0_CLK_N | LVDS0_CLK_N | LVDS0_CLK_N | LDB | |
242 | AD1 | LVDS0_TX1_N | LVDS0_TX1_N | LVDS0_DATA1_N | LDB | |
243 | AD2 | LVDS0_TX1_P | LVDS0_TX1_P | LVDS0_DATA1_P | LDB | |
244 | AE1 | LVDS0_TX2_P | LVDS0_TX2_P | LVDS0_DATA2_P | LDB | |
245 | AE2 | LVDS0_TX2_N | LVDS0_TX2_N | LVDS0_DATA2_N | LDB | |
246 | AE3 | LVDS1_TX0_N | LVDS1_TX0_N | LVDS1_DATA0_N | LDB | |
247 | AE4 | LVDS1_TX1_P | LVDS1_TX1_P | LVDS1_DATA1_P | LDB | |
248 | AE5 | LVDS1_TX2_N | LVDS1_TX2_N | LVDS1_DATA2_N | LDB | |
249 | AE6 | LVDS1_TX3_N | LVDS1_TX3_N | LVDS1_DATA3_N | LDB | |
250 | AE7 | LVDS1_CLK_N | LVDS1_CLK_N | LVDS1_CLK_N | LDB | |
251 | AF1 | LVDS0_TX3_N | LVDS0_TX3_N | LVDS0_DATA3_N | LDB | |
252 | AF2 | LVDS0_TX3_P | LVDS0_TX3_P | LVDS0_DATA3_P | LDB | |
253 | AF3 | LVDS1_TX0_P | LVDS1_TX0_P | LVDS1_DATA0_P | LDB | |
254 | AF4 | LVDS1_TX1_N | LVDS1_TX1_N | LVDS1_DATA1_N | LDB | |
255 | AF5 | LVDS1_TX2_P | LVDS1_TX2_P | LVDS1_DATA2_P | LDB | |
256 | AF6 | LVDS1_TX3_P | LVDS1_TX3_P | LVDS1_DATA3_P | LDB | |
257 | AF7 | LVDS1_CLK_P | LVDS1_CLK_P | LVDS1_CLK_P | LDB | |
258 | D1 | CSI_D1P | CSI_D1P | CSI_D1P | MIPI_CSI | |
259 | D2 | CSI_D1M | CSI_D1M | CSI_D1M | MIPI_CSI | |
260 | D3 | CSI_D2P | CSI_D2P | CSI_D2P | MIPI_CSI | |
261 | E1 | CSI_D0P | CSI_D0P | CSI_D0P | MIPI_CSI | |
262 | E2 | CSI_D0M | CSI_D0M | CSI_D0M | MIPI_CSI | |
263 | E3 | CSI_D2M | CSI_D2M | CSI_D2M | MIPI_CSI | |
264 | F1 | CSI_CLK0M | CSI_CLK0M | CSI_CLK0M | MIPI_CSI | |
265 | F2 | CSI_CLK0P | CSI_CLK0P | CSI_CLK0P | MIPI_CSI | |
266 | F3 | CSI_D3P | CSI_D3P | CSI_D3P | MIPI_CSI | |
267 | G3 | CSI_D3M | CSI_D3M | CSI_D3M | MIPI_CSI | |
268 | G1 | DSI_D0P | DSI_D0P | DSI_DATA0_P | MIPI_DSI | |
269 | G2 | DSI_D0M | DSI_D0M | DSI_DATA0_N | MIPI_DSI | |
270 | H1 | DSI_D1M | DSI_D1M | DSI_DATA1_N | MIPI_DSI | |
271 | H2 | DSI_D1P | DSI_D1P | DSI_DATA1_P | MIPI_DSI | |
272 | J1 | DSI_CLK0M | DSI_CLK0M | DSI_CLK0_N | MIPI_DSI | |
273 | J2 | DSI_CLK0P | DSI_CLK0P | DSI_CLK0_P | MIPI_DSI | |
274 | A6 | MLB_SP | MLB_SP | MLB_SIG_P | MLB | |
275 | A7 | MLB_DP | MLB_DP | MLB_DATA_P | MLB | |
276 | B6 | MLB_SN | MLB_SN | MLB_SIG_N | MLB | |
277 | B7 | MLB_DN | MLB_DN | MLB_DATA_N | MLB | |
278 | C7 | MLB_CP | MLB_CP | MLB_CLK_P | MLB | |
279 | C8 | MLB_CN | MLB_CN | MLB_CLK_N | MLB | |
280 | A2 | PCIE_RXM | PCIE_RXM | PCIE_RX_N | PCIE | |
281 | A3 | PCIE_TXP | PCIE_TXP | PCIE_TX_P | PCIE | |
282 | B2 | PCIE_RXP | PCIE_RXP | PCIE_RX_P | PCIE | |
283 | B3 | PCIE_TXM | PCIE_TXM | PCIE_TX_N | PCIE | |
284 | U24 | PMU_GPIO0 | PMU_GPIO0 | PMU_GPIO0 | PMIC | |
285 | V24 | DETVSB_PMU | DETVSB_PMU | DETVSB_PMU | PMIC | |
286 | W24 | HRESET_PMU | HRESET_PMU | HRESET_PMU | PMIC | |
287 | Y24 | PWRON_PMU | PWRON_PMU | PWRON_PMU | PMIC | |
288 | C9 | USB_H1_VBUS | USB_H1_VBUS | USB_H1_VBUS | PMU | |
289 | D6 | USB_OTG_VBUS | USB_OTG_VBUS | USB_OTG_VBUS | PMU | |
290 | A21 | SD1_DAT3 | SD1_DAT3 | PWM1_OUT | PWM1 | |
291 | D15 | RTC_BATT | RTC_BATT | RTC_BATT | RTC_BATT | |
292 | A10 | SATA_RXP | SATA_RXP | SATA_PHY_RX_P | SATA_PHY | |
293 | A9 | SATA_TXM | SATA_TXN | SATA_PHY_TX_N | SATA_PHY | |
294 | B10 | SATA_RXM | SATA_RXN | SATA_PHY_RX_N | SATA_PHY | |
295 | B9 | SATA_TXP | SATA_TXP | SATA_PHY_TX_P | SATA_PHY | |
296 | A1 | JTAG_TMS | JTAG_TMS | JTAG_TMS | SJC | |
297 | B1 | JTAG_TRSTB | JTAG_TRSTB | JTAG_TRSTB | SJC | |
298 | C1 | JTAG_TDO | JTAG_TDO | JTAG_TDO | SJC | |
299 | C2 | JTAG_TDI | JTAG_TDI | JTAG_TDI | SJC | |
300 | C3 | JTAG_TCK | JTAG_TCK | JTAG_TCK | SJC | |
301 | A14 | ONOFF | MX6_ONOFF | SRC_ONOFF | SRC | |
302 | B14 | BOOT_MODE0 | BOOT_MODE0 | SRC_BOOT_MODE0 | SRC | |
303 | B15 | BOOT_MODE1 | BOOT_MODE1 | SRC_BOOT_MODE1 | SRC | |
304 | M3 | CSI0_DAT10 | UART1_TX | UART1_TX_DATA | UART1 | |
305 | N3 | CSI0_DAT11 | UART1_RX | UART1_RX_DATA | UART1 | |
306 | H25 | EIM_D28 | UART2_CTS | UART2_CTS_B | UART2 | |
307 | H26 | EIM_D27 | UART2_RXD | UART2_RX_DATA | UART2 | |
308 | H27 | EIM_D26 | UART2_TXD | UART2_TX_DATA | UART2 | |
309 | J25 | EIM_D29 | UART2_RTS | UART2_RTS_B | UART2 | |
310 | F25 | EIM_D25 | UART3_RXD | UART3_RX_DATA | UART3 | |
311 | G25 | EIM_D31 | UART3_RTS | UART3_RTS_B | UART3 | |
312 | G26 | EIM_D24 | UART3_TXD | UART3_TX_DATA | UART3 | |
313 | G27 | EIM_D23 | UART3_CTS | UART3_CTS_B | UART3 | |
314 | AE8 | KEY_COL0 | UART4_TXD | UART4_TX_DATA | UART4 | |
315 | AF8 | KEY_ROW0 | UART4_RXD | UART4_RX_DATA | UART4 | |
316 | AE9 | KEY_ROW1 | UART5_RXD | UART5_RX_DATA | UART5 | |
317 | AF9 | KEY_COL1 | UART5_TXD | UART5_TX_DATA | UART5 | |
318 | A5 | USB_OTG_DP | USB_OTG_DP | USB_OTG_DP | USB | |
319 | A8 | USB_H1_DN | USB_HOST_DN | USB_H1_DN | USB | |
320 | B5 | USB_OTG_DN | USB_OTG_DN | USB_OTG_DN | USB | |
321 | B8 | USB_H1_DP | USB_HOST_DP | USB_H1_DP | USB | |
322 | C6 | GPIO_1 | USB_OTG_ID | USB_OTG_ID | USB | |
323 | A12 | SD3_DAT0 | SD3_DAT0 | SD3_DATA0 | uSDHC3 | |
324 | B11 | SD3_DAT1 | SD3_DAT1 | SD3_DATA1 | uSDHC3 | |
325 | B12 | SD3_DAT3 | SD3_DAT3 | SD3_DATA3 | uSDHC3 | |
326 | C10 | SD3_CLK | SD3_CLK | SD3_CLK | uSDHC3 | |
327 | C13 | SD3_DAT2 | SD3_DAT2 | SD3_DATA2 | uSDHC3 | |
328 | C14 | SD3_CMD | SD3_CMD | SD3_CMD | uSDHC3 | |
329 | M23 | VDD_3V3 | VDD_3V3 | VDD_3V3 | VDD_3V3 | |
330 | M24 | VDD_3V3 | VDD_3V3 | VDD_3V3 | VDD_3V3 | |
331 | N24 | VSNVS | VSNVS | VSNVS | VSNVS | |
332 | A15 | GPIO_9 | WDOG_B | WDOG1_B | WDOG1 | |
333 | A4 | CLK1_P | CLK1_P | XTALOSC_CLK1_P | XTALOSC | |
334 | B4 | CLK1_N | CLK1_N | XTALOSC_CLK1_N | XTALOSC | |
335 | C4 | CLK2_N | CLK2_N | XTALOSC_CLK2_N | XTALOSC | |
336 | C5 | CLK2_P | CLK2_P |
