What all drivers need to be enabled in P2041 where altera fpga connected on SPI bus
gouravjain
Dear all,
In my design based on P2041RDB board, Altera FPGA is connected on SPI bus. I want to perform read/write operation on FPGA. Pls let me know what all drivers need to be insert to make it work.
My linux version is: Linux-3.8.13-rt9-QorIQ-SDK-V1.4
regards,
Gourav
Pavel
Look at the Chapter 8.6 of SDK 1.4 documentation about eSPI using.
See also the Chapter 7.15 of SDK 2.0-1703 documentation:
https://www.nxp.com/docs/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
Pavel Chubakov
gouravjain
hi,
can you pls let me know about the spi-altera.c ? What is does and do i need to use it for my requirement ?
gouravjain
Can you pls comment on my above query??
Basically i need to transfer data from user space, to Altera FPGA which is connected on SPI bus. Not getting hint how to start..
regards,
Gourav
