Imx6q board connect with register touch screen. It is working good. Now i want to used LCD capacities touch screen but did display did not work. I found that require to change boot environment, but i did not able to enter uboot> console. OS used is kitkat 4.4.
Please note that this command prompt appears not on a graphic display attached to i.MX but on the terminal connected to UART.
You need to connect PC to "debug UART" port of i.MX board and run virtual terminal on this PC.
Victor
Thanks to reply.
I came to know that console is disable, So, Is there other way to enable boot configuration?
