After opening the TagXplorer choosing the listet SCL3711 is possible, but trying to connect the SCL3711 failes with the message: "Reader is not supported !!!"
The SCL3711-Firmware is original by NXP as far as I know. Is there a newer firmware than from 2014 available?
vikr
Hello Viktor Krön, sorry for the delay, TagXplorer does not support SCL3711 for now, there are other readers supported, in the release notes there used to be a note "SCL3711 not working stable" and im not sure why it was removed but this is not supported by the moment, my apologies for the inconvenience this means to you and your project.
Jonathan
Hi Jonathan Iglesias,
>Hello Viktor Krön<https://community.nxp.com/people/vikr>, sorry for the delay, TagXplorer does not support SCL3711 for now,
SCL3711 is still annonced as one oft he supported readers
the firmware is still the originally written and sold by NXP (to SCM)
bougt this NFC Tag Starter Kit by identive: http://www.identivenfc.com/en/nfc-software-development-kit-sdk/nfc-ndef-tag-editor-kit.htm because of the ducumented suppurt:there (after checking also the NXP-Website)
What shouldt I have made better?
any suggestions - exept buying another reader - are welcom
kindly regards
Viktor Krön
Von: Jonathan Iglesias
Gesendet: Dienstag, 27. März 2018 16:27
An: Krön, Viktor
Betreff: You have been mentioned by Jonathan Iglesias in Re: TagXplorer is designed to work with the Reader SCL3711, but did not. in NXP Community
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
by Jonathan Iglesias<https://community.nxp.com/people/jonathaniglesias?et=notification.mention> in Re: TagXplorer is designed to work with the Reader SCL3711, but did not. in NXP Community - View Jonathan Iglesias's reference to you<https://community.nxp.com/message/999854?commentID=999854&et=notification.mention#comment-999854>
