Hy everyone!
I have a question concerning recovery of a bricked KW41Z (on a Rigado R41Z Evaluation Board).
When testing Segger Embedded Studio I didn't check if the area for setting flash secure and mass erase bits was exluded from allowed memory ranges (trusting the default settings).
J-Link can now access the device but it cannot erase or unlock it.
"Readout protection is set and mass erase is disabled. J-Link cannot unprotect the device."
After some research, finding tips for unlocking other Kinetis MCUs I currently think that there is no way of recovering the device.
But I wasn't able to find something KW41Z specific. So my question: Is it really dead? :smileywink:
Thank you and best regards
Thomas
Hi Thomas Bigler
The only method to recover a secured device is to launch a mass erase command. Unfortunately, if you Jlink debugger mas your device as protected and mass erase disable. then yes, there is no way to recover your device. I would like to recommend you next link:
How (not) to Secure my Microcontroller | MCU on Eclipse
Jorge Alcala
Thanks for your answer and the link, I was actually expecting that.
So this microcontroller will forever keep its 5 line hello world program :smileywink:
I already adapted the linker script (default one from Segger Embedded Studio is incorrect) so that this will not happen again.
Best Regards
Thomas
