Timing behaviors of lpc1114fn28
Question asked by Si Gao on Feb 26, 2018
Latest reply on Mar 1, 2018 by Fall Guy
I was working on a small project based on a lpc1114fn28 processor. Although my program runs successfully, I kept noticing some wired timing behaviors. For instance, if I wrote two identical functions in ASM with different names, sometimes their executing times are not exactly the same. Specifically, one function (in disassembly codes) is
 16a:      f3bf 8f6f              isb          sy
 16e:      681c                   ldr          r4, [r3, #0]          ; (Read SysTick)
 170:      e004                   b.n         0x17c
 172:      46c0                   nop                                      ; (mov r8, r8)
 174:      46c0                  nop                                      ; (mov r8, r8)
 176:      46c0                  nop                                      ; (mov r8, r8)
 178:      46c0                  nop                                      ; (mov r8, r8)
 17a:      46c0                  nop                                      ; (mov r8, r8)
 17c:      681d                  ldr          r5, [r3, #0] ]        ; (Read SysTick)
According to the SysTick, it takes 7 cycles. However, for the same codes in a different address
1c8:       f3bf 8f6f              isb          sy
 1cc:       681c                  ldr          r4, [r3, #0]        ; (Read SysTick)
 1ce:      e004                  b.n         0x1da
 1d0:      46c0                  nop                                      ; (mov r8, r8)
 1d2:      46c0                  nop                                      ; (mov r8, r8)
 1d4:      46c0                  nop                                      ; (mov r8, r8)
 1d6:      46c0                  nop                                      ; (mov r8, r8)
 1d8:      46c0                  nop                                      ; (mov r8, r8)
 1da:      681d                  ldr          r5, [r3, #0]          ; (Read SysTick)
The SysTick suggested it take 5 cycles.
In theory, since b.n takes 3 cycles and ldr takes 2 cycles, it should always take 5 cycles to run the above codes. However, I constantly found that sometimes it takes 2 extra cycles. I was wondering what are these extra 2 cycles for? Any idea?
Si
