Sync byte field for LIN module with MPC5777M EVM board ?
anishchoudhary
I am working with MPC5777M / MPC5748G EVM board on LINFlexD_LIN module.In the master frame how to configure the Sync byte as 0x55 to decide the Sync field is OK and then decide the transmission rate. Find the Sync byte in following master frame image :
http://www.kvaser.com/wp-content/uploads/2014/02/fig3-lin-frame-example1.jpg
Tags (2)
PetrS
Master always send 0x55 as Sync field of the header. This is not configurable.
BR, Petr
