How to Speed up Radar signal processing ?
pingfang
b55689‌@
Hi, I am using MPC5775K. I found that the speed of radar detected targets was very slowly (just used z4 core). Now, I want to use the z7 core and z4 core .If so, can I solve this problem? For most important, how to use z7 and z4 core?
Tags (3)
petervlna
SPT and Radar modules are not supported via free support.
If you require help with SPT please contact FAE assigned to your company for further process.
Radar applications are very application specification dependent and can only be supported directly for application needs.
Peter
pingfang
Thank you all the same.
