Pietro di Castri
SDA destroyed
Discussion created by Pietro di Castri on Feb 23, 2018
Latest reply on Feb 28, 2018 by Alice_Yang
Hello everyone
I did the wrong thing with the SDA interface, just used the JTAG on the FRDM board for the wrong target. Now it is necessary to program again. I suppose it is enough to use again the JTAG and reprogram the small processor. but it does not work. The files I find are .bin and I don t know how to use with the KDS. Is there a way to build the .elf from the source code?? Or a valid suggestion to repair everything..
Suggestion needed
Thank You everyone
Pietro
