i.MX6 HDMI DDC I2C master bus driver for Linux
florinmaticu
I am working on a project based on i.MX 6QuadPlus SABRE Development Board. The HDMI DDC pins (data and clock) are connected to HDMI TX directly. Therefore we are using the I2C master bus from the HDMI TX.
In the BSP Linux 4.9.11_1.0.0 BSP I could not find a driver implementation for this particular i2c bus.
Is there a driver implementation for this i2c bus ?
Thank you!
Bio_TICFSL
Hi florin,
HDMI DDC IOMUX via EIM_EB2 & EIM_D16
Open imx6qdl-sabresd.dtsi file , please! find these lines:
pinctrl_hdmi_hdcp: hdmihdcpgrp {
                                    fsl,pins = <
                                                MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x4001b8b1
                                                MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA 0x4001b8b1
and replace
MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL & MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA
with
MX6QDL_PAD_EIM_EB2__HDMI_TX_DDC_SCL & MX6QDL_PAD_EIM_D16__HDMI_TX_DDC_SDA
or if you are in latest kernel you do not need to change anything.
florinmaticu
Thanks for your reply.
For our hardware we already have EIM_D16 and EIM_EB2 connected to I2C2 signals.
fsl,pins = <
MX6QDL_PAD_EIM_D16__I2C2_SDA 0x0001B0B0
MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x0001B0B0
