DSP56F826 Programming Issue
markoudshoorn
Hi - I am working with a legacy product that uses a DSP56F826 part. All I have is the s record file. Bought a USB-TAP and downloaded 56800E Flash Programmer ver 1.2. Can't figure out what .cfg file to use for this part. Do if have to make my own. Can someone help me with this?
markoudshoorn
Jennie -
First Thank You for helping finding info on this is next to impossible.
One last question - Do yo know if an Axiom parallel to jtag programmer will work with  Flash_Over_Jtag?
Thanks Mark
ZhangJennie
Hi Mark,
Yes, Axiom parallel to jtag programmer supports Flash_Over_Jtag.
Jennie Zhang
ZhangJennie
Hi Mark
56800E Flash Programmer is for 56800E core DSC only.
DSP56F826 has 56800 core inside which is not supported by 56800E Flash Programmer.
For DSP56F826, please use Flash_Over_Jtag instead. I just tried looking for Flash_Over_Jtag download link for you but didn't find out. If you need it, I suggest you create a private case to NXP support team:
https://community.nxp.com/docs/DOC-329745?sr=search&searchId=6a877a33-4094-4f26-af47-8a12a076a7b2&se...
Jennie Zhang
markoudshoorn
Do you know if it will work with USB-TAG?
Flash_Over_Jtag
Mark Oudshoorn
moudshoorn@verizon.net
ZhangJennie
No, Flash_Over_Jtag supports parallel interface only.
Jennie Zhang
