I work with the MFRC522 chip, I am looking for a document "Excel-Worksheet "Antenna Topology 1" in AN1444xx" which is mentioned in AN1445
Have you checked the antenna design ZIP file available under the application's note section in the MFRC52202HN1 documentation tab?
Estephania
Thank you, I was looking for it.
Estephania
