I'm using a MON08 interface on 908JB16's.
Everything works fine, i can program, step, run, read flash&RAM etc.
But.. some of my boards exhibit a annoying problem:
Soft reset doesnt work:
Attempting soft reset of HC08 device ... Unsuccessful.
Starting powerdown reset sequence ...
Only on some of my boards... Others give:
Attempting soft reset of HC08 device ... Success.(RSR=$xx)
There is no difference between boards with a working soft reset and ones that wont.
Same hardware, same cpu (datecode), same flash contents, same cable...
Any idea's as to what might cause this ?
Message Edited by MrBean on 2008-10-16 03:33 PM
