mpc5604e and canoe issue
shivagurrala369
iam able to send the data to the canoe from mpc5604e controller but iam not able to recieve the data to the mpc5604e controller from the canoe what might be the problem
abhishek_reddy5
can you please share me the code of mpc5604e sending frames to canoe?
PetrS
what is the message sent by CANoe? Do you see a message on the bus and on MCU RX pin?
Did you prepare MB for receiving? If yes, how?
Did you properly set masking registers?
Do you see MB flag set?
Do you use SW polling or interrupt?
BR, Petr
