Is there a way to power up S32k with 3.3v source on EVB board, or is only limited to USB 5V or 12V source?
Actually, it is possible, you need to dump R64 and populate R63 or J10.1-2.
based on EVB datasheet - the USB 5V or 5-12V external power supply is the only option.
Jiri
