KW41Z - Power Consumption
Question asked by Jia Na Lai on Feb 13, 2018
Latest reply on Mar 15, 2018 by Jia Na Lai
Based on the datasheet, the power consumption of KW41Z in VLLS1 buck mode as shown as below. May i know under what condition to achieve this results? What are the configuration for the GPIOs (pull low/pull high, input/output and etc.) and clock before enter VLLS1?
Attached is my schematic, I have measured at VBAT point and got the power consumption around 14uA. It is quite much different compare with the spec from datasheet. Am I measured at the correct point?
