Salih Kucukbayrak
Keil create many errors with SDK 2.3.0 for LPC54628
Discussion created by Salih Kucukbayrak on Feb 11, 2018
Latest reply on Feb 23, 2018 by Salih Kucukbayrak
I can't use SDK with Keil "Manage Run-Time Environment". Build action not complate, create many error.
"C:\Keil_v5\ARM\PACK\NXP\LPC54628_DFP\2.3.0\drivers\fsl_clock.h(689): warning:  #66-D: enumeration value is out of "int" range kNONE_to_NONE = 0x80000000U,"
".\Objects\dff.axf: Error: L6218E: Undefined symbol POWER_SetPLL (referred from fsl_clock.o)."
".\Objects\dff.axf: Error: L6218E: Undefined symbol POWER_SetUsbPhy (referred from fsl_clock.o)."
".\Objects\dff.axf: Error: L6218E: Undefined symbol POWER_SetVoltageForFreq (referred from fsl_clock.o)."
".\Objects\dff.axf: Error: L6218E: Undefined symbol main (referred from __rtentry2.o)."
Another problem for Phy chip. "Manage Run-Time Environment" suggest ethernet Phy with spi or serial. I can't select on board ethernet interface with Lan8720. This chip is behaving like no ethernet.
