Java.lang.NullPointerException
alphatsai
When I click exit, MCUXpresso always show Java.lang.NullPointerException error message.
And I can't shot down or exit MCUXpresso
BlackNight
Could you post the .log file insider your workspace .metadata folder? Usually that log file contains useful information and the stack trace to identify what the problem is.
alphatsai
You can download log from below link.
.log - Google Drive
liborukropec
please try patched plugin in the link bellow. Please do following:
  1. close the MCUXpresso IDE
  2. do a backup of the plugin com.nxp.swtools.periphs.gui_0.0.1.201711131454.jar located typically here: c:\nxp\MCUXpressoIDE_10.1.1_606\ide\plugins\
  3. replace it with this https://mcuxpresso.nxp.com/staticdata/com.nxp.swtools.periphs.gui_0.0.1.201711131454.jar
  4. start IDE again
Please let me know if that helped with the Null Pointer dialog.
Libor
alphatsai
It's good, no show error message again when the MCUXpresso IDE close.
Thanks for your help.
liborukropec
the log helped, it seems like a problem in the Peripherals tool. I'll pass it to the team and let you know, if there's any workaround. Are you using the Peripherals tool in your project?
Libor
