CLRC 66301 Reader distance problem
善友曹
Hello, I am testing the use of CLRC 66301, the card reading distance is now about 5cm, I want to adjust the antenna parameters to make the reader distance up to 30 cm, if possible, how to adjust?thank you very much.
IvanRuiz
Please refer to our NFC Reader portfolio in which it is shown the maximum distances:
https://www.nxp.com/docs/en/brochure/939775017564.pdf
Ivan.
