FLASH Erasing issue
FLASH Erasing issue
sagarprajapati
i m using mk64f12 series controller and sst25vf32b flash. i am using uep library to code.upto certain amount everyhing is fine but after that data is saved but after reboot i am loosing all the data. Untill i am reboot it.....it works good and i double check it it is not overflowing.
