Christian Mouilleron
Running sdcard fatfs exemple from sram
Discussion created by Christian Mouilleron on Feb 6, 2018
Latest reply on Feb 20, 2018 by Christian Mouilleron
I try to make run a sdk exemple from sram on a frdmK64F.
As explained in this thread https://community.nxp.com/thread/435198, i  remove the flash section from the memory map in the Memory Configuration Editor, and tick the "Link application to RAM" option.
I can debug this project with a PEmicro interface debugging but it stays stuck in the delay function because the systick event is never triggered.
This problem does not appear on flash.
Do you have some suggestion ?
Thanx.
