We are using i.MX6QDL based custom board running Android 7.1.1. On this device when executing GTS tests, we are observing failures related to audio/video playback tests as below.
Also attached the logcat logs. Please provide your input on what could be the issue.
Thanks.
Is there a possibility that you can upgrade to our newer Android version (7.1.2)?
Some errors were fixed in that version, probably in that version the GTS test pass.
Diego.
