How to create IAR project?
wpj1018
LPC822 is used in my project, I want create a new IAR project, how to create?
If not create a new IAR project, how to add a new IAR project base on the workspace of LPC824_Example_Code_Bundle_IAR_r1.0.
jeremyzhou
Hi fred wang,
the opportunity to serve you.
Please referring to the Creating an application project section in the IAR Embedded Workbench IDE User Guide whose link is below:https://www.brown.edu/Departments/Engineering/Courses/En164/EWARM_UserGuide.ENU.pdf
TIC
wpj1018
Thanks!
