We are using OM13092 together with MCUXpresso
Downloading for fist time no trouble but for second time after little change the program was not possible.
JP5 is open and downloading going via J8 Debugger port.
We have never see the Hello World string.
What are we doing wrong.
Hello Gerard,
Each project as default, comes with semi-host active, this means that everything will be printed in the console of MCUXpresso, that is the reason why you can't see anything. To change this an see the hello world in tyy terminal please follow the next steps:
After these steps you should be able to see the hello world in the terminal.
Attach you will find an image where the steps mentioned before are shown.
Victor.
