OM27462CDK Board's TDA8026 I2C Communication
khalid_anindyag
Hello, sir / madam.
Please help me successfully transmit a byte to the TDA8026 IC on the OM27462CDK board. These are what I've done so far, please correct me if I did something wrong or missed something :
Init I2C
Config I2C with 0xF4 baudrate
Set GPIO 3 of PN7462 to HIGH so the TDA's SDWNN pin goes HIGH.
Transmit 1 bytes of 0x00 to slave address 0x48 (this returns 0x8280).
Thank you for your kind response.
Khalid
Kan_Li
Hi Khalid,
I just have ref code for LPC connected with TDA8026. and if you need it, you have to create a private ticket in our web site. https://nxpcommunity.force.com/community/CommunityContextPage?subcf=Tickets%20-%20Link%20Click
Kan
wowfoot
Hi! The link above is no longer available. Could you share it again?
Bonat
Hello! The link is no longer available. Could you share it again?
thiago_machado
Bonat
Hello, the second link is no longer available again. Could you share it again?
Kan_Li
Hi Khalid,
Kan
