Need Instruction for ARM Cortex R-4
shaileshagrahar
Hi all,
I need help for to convert logic in following way:
if 1st bit set in  (00000000000000000000000000001)  i can get 1
f 1st bit set in  (00000000000000000000000000100)  i can get 2
f 1st bit set in  (00000000000000000100000000000)  i can get 11
f 1st bit set in  (10000000000000000000000000001)  i can get 31
is there any instruction for ARM cortex-r4 .
" I mean to say i just want to get the set bit position number in  uint32 data ".
Please help me .
danielmartynek
What device do you use? Is it NXP?
I would recommend contacting ARM support.
shaileshagrahar
Hi Daniel ,
Thanks for your attention, It is not from nxp but it BCM895xx series of.
But if possible suggest me any solution .
Thanks!
