DEVKIT-ZVL128. LIN Bootloader Master-node, stuck at Clock_init()
Question asked by chury jeong on Jan 29, 2018
Latest reply on Mar 27, 2020 by ko ik
When I run "S12Z_LIN_MagniVBootloader_Translator" of AN5389SW on DEVKIT-ZVL128,
PC(program counter) seems to be stuck at Clock_init(CLK_32_MHZ).
void main(void) {
unsigned char dataCounter,phraseCounter;
CPMUVREGCTL_VREG5VEN = 1; /* 5v regulator */
Clock_init(CLK_32_MHZ); // Never return here.
SCI1_init(32000000,19200); /* SCI1 is linked to PC communication */
MODRR0_SCI1RR = 1; /* TX ROUTED TO PT5 (white)/ RX ROUTED TO PT4(green) */
LIN_init();
in Clock.c,
void Clock_init(unsigned char bus_clk){
CPMUOSC_OSCE = 0; /* Disable external oscillator */
if(bus_clk==CLK_8_MHZ){
//CPMUREFDIV_REFDIV = 3;
CPMUREFDIV_REFFRQ = 0;
CPMUSYNR_SYNDIV = 15;
CPMUSYNR_VCOFRQ = 1;
CPMUPOSTDIV_POSTDIV = 1;
else if(bus_clk == CLK_12_5_MHZ){
CPMUSYNR_SYNDIV = 24;
else if(bus_clk == CLK_24_MHZ){
CPMUSYNR_SYNDIV = 47;
else{
CPMUSYNR_SYNDIV = 31;
CPMUPOSTDIV_POSTDIV = 0;
while(CPMUIFLG_LOCK==0){} // Never return here.
CPMURFLG = 0x60; /* Clear PORF and LVRF */
CPMUIFLG_LOCK seems not to be changed to "1".
Question #1)
- I did not changed any strap option on the EVM board since uppack.
- Do I need to change some strap to make the EVM board work as LIN Master.
- Why clock is not locked, please let me know the reason.
