how to write datas into flash when programming
zhujiuzhujiu
I want write the configuration datas into flash when download the *.srec file。
e.g.
   I want write data 0x12 into adress 0x70000;
   S12 series MCU can use  @0x70000 = 0x12 ;
But S32K144,I don't know how to operation。
Thanks, BR!
jiri_kral
the only option is create custom section in linker file and put your constants in that section. For inspiration you can look at this example: https://community.nxp.com/docs/DOC-335619
Jiri
