target toolchain
target toolchain
sachindhoundiya
Hello Yuri ,
Right now i compiled code in eclipse and copy output file in memory card. then run the output file in i.mx6ull.
Is there any toolchain to compile in imx6ull for c code. so that we have not to do copy in memory card the output file.
Yuri
  You should provide the toolchain to Your target.
install gcc and toolchain on target rfs
Creating a custom distribution image with Yocto for the RIoTboard
Yuri
