PExDrv v10.4 Update 3 not downloadable
falstaff
Senior Contributor I
When trying to download "PExDrv v10.4 Update 3" from Processor Expert Software, Microcontroller Driver Suite|NXP
ZhangJennie
Hi Stefan,
Do you mean PE for Kinetis v3.0.2? I just checked, there is no problem download it from my side.
Please try again, if still has problem, I would suggest you change another network.
Jennie Zhang
falstaff
No, that is not the download I was looking for. Back when I posted the thread, there used to be a download titled exactly "PExDrv v10.4 Update 3", and pointed to a DriverSuite_10.4.3_update.zip. However, it seems that the download got removed.
The reason I am asking is because I am looking for a DDR validation tool for Vybrid. According to https://community.nxp.com/message/571966?commentID=571966#comment-571966  it needs Processor Expert 10.4 plus (I guess at least) Update 1.
In between we managed to update Processor Expert 10.4 through the internal update mechanism.
ZhangJennie
Hi Stefan.
I just checked our internal backup, we only have DriverSuite 10.4.1 and 10.4.2 updates. They were both released in 2014.
Are these two versions ok for you? if yes, I suggest you create a private ticket to technical support:
How to submit a new question for NXP Support
We will send it to you via Transweb.
Jennie Zhang
falstaff
I think Update 2 should be good. Thanks!
ZhangJennie
ok, please create a private ticket and send me case number, I will track.
Jennie Zhang
