ADC on MK10DX64VLFS returs zero
harrykoukoutos
On a new project with a MK10DX64VLFS, trying to read the ADC returns zero if the ADC is uncalibrated and a small value, 3-6 counts, after calibration. The same happens in internal channels, too, as the temperature sensor. Any ideas what to check? The code used is similar to the example KQRUG.pdf and to code used on a MK10DX256ZVLQ10, that works just fine. Have we missed a major difference between chips?
Robin_Shen
Please refer the adc_demo in Kinetis 50MHz bare metal sample code(REV 1.6).
Robin
